Hey guys,
We bought a 1987 Toyota 4x4 truck with a 22R / 5 speed / 31x10.5x15 tires / 199,xxx miles .
I would like to ask a few questions please.
What fuel mileage might we expect from this truck 15? 17mpg?
Also, today I installed a new Weber 32 / 36 carb. The sparse installation instructions left a lot to the imagination. I was told to install the supplied EGR plate onto the intake manifold and screw the vacuum supplied vacuum fitting. To do this I had to remove a steel elbow and tube that runs along side the valve cover to the rear of the engine. I did that but the instructions did not say what to connect to this fitting. Should I connect the hose from the PCV valve? I also have a plastic hose barb in the supplied air filter housing, what shall I connect there?
And finally the distributor on my truck has TWO vacuum hoses. DO I connect BOTH of these to thew Weber or just use ONE distributor vacuum?
I can supply photos if that helps carify my questions.
Thanks for all input!
Tony P
New Salem, NC
Tony P
New Salem, NC
