I am quite new to the LC world and 1/4 of when it comes to being a mechanic.
I was looking under my 94 Landcruiser this afternoon and noticed that a bolt with a rubber piece on it was leaking grease. The bolt is located at the rear wheel passenger side next to the wheel. Should I be concerned? Is it difficult to fix?
The grease should not be a problem on the sway bar link. Does not appear to be a zerk fitting on it unless it is snapped off.
Would not loose any sleep over it at this point.
I believe you have to replace the entire end. Cdan would know (and have the right prices as well).
Some people have had luck getting a needle grease fitting and squirting grease into the boot (via the hole already there), then sealing it up with some RTV sealant of something similar. (Duct tape for a redneck fix. )
