- Joined
- Jul 29, 2007
- Threads
- 6
- Messages
- 16
I'm getting squeaking noise from the front end when I turn the wheels at low speed. It seems to happen when I turn the steering wheel to the right but not in a straight line or turning to the left. Seeing as it's not feasible for me to go through the rest of my life never turning right in a parking lot, I think I'd like to fix it! Could this be caused by the steering knuckles, trunion bearings or something else entirely?
OK, first the disclaimers:
1) I searched the FAQ (keywords: noise, turning), couldn't find anything that was on target with what I'm hearing.
2) My steering knuckles need new seals, this I know from the goop caked on the outside.
Here's some more detail, sorry for writing a novel here.
I have just imported the truck (JDM) and had it in the shop for the compliance inspection, I had the shop do the fluids while they did the compliance work. They mentioned that the steering knuckle seals needed redoing and that he felt the trunion bearings should also be replaced. The quote he gave me for the seal kit for the steering knuckles was $300 (only for the parts!) When I called another place that specializes in LC's (especially JDM) they quoted me $13 or $14 per seal.
I'm a newbie at wrenching on vehicles but I like to get in there and figure out how stuff works or doesn't work, it's time to start. I've ordered the Max Ellery service manual for the truck (with a manual I can usually figure most stuff out.) I can't wait to get in there, pull everything apart and forget how it all goes back together. Besides, I'm always looking for an excuse to buy more tools.
My questions and they are many, this is just the beginning:
Thanks for any help you can give, and if you feel the need, flame me, I can take it.
Thanks,
Matt
- The terms Birfield and steering knuckle seem to be used interchangeably, are they the same thing?
- How would I know if the trunion bearings need re-packing?
- What's likely to be causing the d**n squeaking noise? If it's not the birf's/steering knuckles, I'd like to sort it out while I'm in there doing the birf job.
Thanks,
Matt
