Newbie needs some help with codes
Hi All
Recently purchased a 97 non locked LX450 with 155K on it. The CE light came on and I pulled the codes, they are as follows:
P040103
PO70101
P070102
The CE light came on about a week ago with the 401 code. I have recently replaced the EGR valve and the code went away for about a day then showed up the the 701 codes tonight.
The car seems to run fine, just a little rough. My wife had a little trouble starting it before I replaced the egr now its starts fine but still showing the code.
I been reading this board for a while, learning all I can. Seems like a great group of people, any help would be appreciated.
Thanks!
Ben
WOW 3 days and no responses????
Any help would be appreciated!!
Ben, you got too many digits in the codes. The only help I can give you is from a list of OBD2 codes I printed off. The "0401" is: EGR Flow Insufficient. And there's no 0701 on my list. Hopefully someone that knows OBD2 will chime in!
EDIT: My list show the format PXXXX for OB2 codes. With XXXX being numbers following the P.
P040103
PO70101
P070102
Ben,
Your P0401 is the most common and most documented of all the OBD-II codes on your 80-Series. You have a lot of reading to do so you can get up to speed on this issue. FYI, you've wasted money like all of us do when replacing the EGR valve. For some reason we think P0401=EGR; therefore replace the EGR valve. In my experience, the EGR valve is very rarely the problem.
I have never heard of a P0701 on an 80-Series. Please check again and let us know.
-B-
Thanks for all the replies. I probably wasted a lot of money because I just ordered a egr temp sending unit and a egr vacuum. The 701 went away after the reset and has not come back, I think it went on when I hit the o/d button, I saw the o/d "off" light did not come on when I disengaged it so I hope the PO didn't take the bulb out because it was flashing. The tranny shifts out fine and the o/d works well so I am not going to go digging just yet. I have replaced the coolant temp sensor because that was another code that I came upon so I guess I will see what happens, and then, replace the other parts if necessary. I did stumble upon the OBD II codes on the FAQ's - they were very helpful. Thanks again for the help!
Ben
Ben,
Yes, you probably wasted a lot of money. You're throwing parts at a problem that sometimes is resolved by cleaning a passageway through the intake and/or replacing some of the small vacuum hoses. The EGR modulator is a frequent point of failure as is the VSV for EGR. The EGR temp sensor is rarely the cause of a P0401.
-B-
Replace both the temp sensor and the vacuum valve. The 401 code went away. Still have the 701 code, any help would be appreciated. I want to be informed if I have to take it to the stealer.
Thanks,
Ben
Thanks,
Ben
Does your code reader give you any verbiage on the P0701?
-B-
What code reader are you using? You are getting too many digits in the codes and codes which no one has heard of nor has reference to. Do you have an AutoZone near you to verify your readings?
Just because a P0401 CEL has shut off does not mean that it will stay off. Been there.
My code reader is a generic one I purchased off ebay... The last 2 digits are in the top right hand corner smaller than the P0701 codes.
I will take it to autozone to verify and post what I find.
Thanks!
Ben
Okay, went to Autozone today. Got these codes:
System too lean bank 1
Probable causes
  • Lean air/fuel ratio - fuel injector
  • Vacuum leak
  • MAF sensor concern
  • Faulty o2 sensor
Any help on narrowing this down would be appreciated. Idle seems a little low at times. CEL comes on after about 15 minutes of driving.
Thanks!
Ben
Ben,
That would be a P0171, not a P0701.
The first place to look is the big rubber tube that goes between the A/F canister and the intake. Inspect this tube carefully; any cracks will cause unmetered air to enter the engine and can cause a P0171. Obviously, an engine that is consistently running too lean is not a good thing and you want to get this fixed as soon as possible. While you are there you can inspect all the hoses attached to the intake and make sure none are leaking.
The P0171 is a 2-trip logic.
What is the maintenance history on your O2 sensors?
-B-
Fixed it.
I checked all the hoses, all where fine. I did the carb spray thing around the intake and found that the EGR had a vacuum leak at the gasket. New gasket and everything is fine. Thanks for all the help!
Ben
