Newbie needs help not found in faq...
Gulf Coast
I have a '97 LC and need new tires I'm currenlty riding on the factory rims.
I will spend ~ 95% of the time on these tires on the pavement as I can't wheel with this until it's no longer my primary commuter.
I want to get bigger and wider tires so it doesn't look like it's packing a soccer mom and do so without a lift.
The faq mentioned AT's which I will most likely purchase, but here's where I would appreciate your expertiese and help:
I noticed '98 and above LC's have 18" wheels compared to my 16"'s. Can I simply swap a pair on? Do they have the same bolt pattern? Assuming this scenario works how tall and wide can I go without a lift and any "major" rubbing issues . By "major" I mean I can drive normally and it rubs when I'm making relatively sharp turns in the parking lot.
Or if I keep my factory 16" wheels how tall and wide can I go without a lift without the "major" runbbing issues defined above.
I know rubbing will come into play at some point, but i had a '97 Wrangler with 33x12.50's (and no lift) and it only rubbed when making very sharp turns. from my vague recollection the wheel wells look very similiar in size and depth.
Please help, I'm riding on threads and need to buy this weekend. Also keep in mind I'n not the Bob Villa of auto mechanics by any stretch of the imagination so respond in Greek...
THANK YOU!
98+ are 5 bolt - no swapping without major work.
THANK YOU!
NO, you cannot swap 98+ rims to your 97 rig. 98+ have only 5 bolts/stud holes where your 97 has 6 holes.
The biggest tires you can fit is either 295 75R16 or 305 70R16 AT tires without rubbing. Hope that helps.
285/75R16 work real nice on the stock height. Even if you are not going to lift it, you will likely see a dramatic improvement in ride and handling if you put on the stock height OME lift. Your old springs and shocks are probably pretty tired by now. If you do this (essentially 33" instead of stock 31") you might want to consider the spedo correction gear that sleeoffroad sells.
IMHO YMMV.
I bought tires before lift, just worked out that way, but point being I put 285/75/16 M/T's on stock susp. with no rubbing or close to it and zero issue. Just a NICE improvement. ;)
You'll be fine with any tire of that size. As Grench said you can install a speedo corrector, I haven't and doesn't bother me. Its not far enough off that I care. 63MPh on mine ends up being around 65mph....
I have the speedo correction in mine. My wife drives it sometimes and its easier to have it be close to accurate than to explain gear ratios and tire sizes.
Thanks to everyone for the info.
Just a few questions based on the replies::
1) What is an OME lift?
2) What are M/T's
Again, thanks for the help.
OME = Old Man Emu (an Austrailian manufacturer of coil springs and shocks; owned by ARB, widely available in the US)
sometimes confused by sloppy typing with OEM = Original Equipment Manufacturer, meaning stock Toyota parts.
M/Ts are Mud terrain tires, the more aggressive tread patterns found on tires designed more for trail performance than street.
I just installed 33" BFG all terrain's (285 75 R16) on my stock suspension and they fill the wheel wells a lot better than the stock tires. The all terrains are very road friendly and will give reasonable trail performance as long as it's not hard core rock crawling you want to do. Mine will be more of an expedition build so it made more sense to go all terrains rather than the mud's.
Looks a lot less like an overgrown shopping cart now.
Next up OME lift and some sliders.
