Newbie Electrical Question
Longview, Texas
Ok my 77 fj40 has been sitting for about 2 years and I decided to go see if I could get it running good again and make it into a trail rig instead of selling and buying a jeep. Anyways, changed all fluids and dropped in a new battery. I attached the negative cable and when I start to put the Positive cable on the little wires attached to Negative side start turning red and smoking. I pulled positive side off and it quit. Any idea why it would do that? Thanks
Little wires on the negative battery terminal? What little wires on the negative battery terminal? None stock. Negative side is ground.
I have no idea what they are for? I assumed they were stock. I guess it is actually 2 wires going into the same one. But it comes off the negative over to the top of the fenderwell and runs down to tub. Any ideas what it could be for if not stock?
Don't know of any stock wires but the negative ground wire connected to the negative battery post. Do they run in the stock harness, or are they on the outside of the taped harness? You'll have to trace them out.
They are inside the stock harness
I don't want to insulte your intelegence but are you sure you have the battery the correct way around?? generally there is one or two fatish wires on the ground terminal and one fat and 2 thin on the positive.
trace the ground wire from the chassie to make sure its the ground terminal and check the battery it might look the same but the terminals can be the other way around
good luck
failling that disconect the altenator and starter motor these are the most likley place for a short to occure if it has been sitting.
What accesories are installed on this rig? Anything I put a stereo into I like to ground the amp directly to the battery. If somebody has pulled an amp out and left a ground wire hanging that could be it. Other than after market you should probably only have one cable coming off the neg terminal going to the head or block, then maybe something lighter, #8, or #6 going the body or chassis.
