Newbie - E-brake leak
Los Angeles, CA
Slowely but surely the 93 LC is coming along.
Hello Mud members. Getting to the e-brake now. The shoes need to be replaced, the hand brake is non existant at this point. Not doing a complete overhaul at this point ($$$), hoping I can re-use the same hardware with new shoes.
But I wanted to ask Mud members what's the deal with this leak. Mechanic pointed it out but didn't tell me more.
A buddy of mine said I need to replace the rear axle seal. Any thoughts?
Thanks.
Well your handbrake is all mechanical drum, not hydraulic so that rules out an "ebrake leak".
Inspect your caliper and make sure thats not brake fluid(probably is not). Likely your rear axle seal is toast and needs to be rebuilt.
Check out the FAQ at the top of the 80 series tech section and read the rear axle section.
Yes, but your ebrake is that round drum brake that sits inside the rear rotor.
When you pull the ebrake handle it expands the shoes seen in your photo until they hit the inside face of the rotor.
There is no fluid involved.
So that tells me 2 things to look at:
-rear axle seal
-Brake fluid leak @ caliper
Take some better photos that aren't 1" away and post them
