Newbie Clutch Question
Southeast of disorder
Ok, the clutch in my '71 40 had a lot of play in it when I started out last night, then went out before traveling 1/2 a mile. Pulled over and checked clutch master cyl. Resevoir was empty. Not sure where it leaked out, but that is the problem right? Never messed with hydro. clutch before, and not very much of a mechanic, yet. Does the clutch master use brake fluid? I'm assuming it needs to be bled like breaks, correct? Where is the bleeder valve? Is there anything else I should check? Fluid lines? There is only the one correct? The clutch was working fine earlier in the day. I guess I should get the repair manuals. Thanks for any help.
Bleeder is on the top of the slave cylinder. Probably a leaking slave, but if it is a slow leak, you might get by with filling it and bleeding it.....for a while. Best to replace both master and slave at the same time. Not a difficult job at all.
GL
Ed
You should be able to see where your leak is, and it'll be at either the master or the slave as Ed said. Just find the smaller master cylinder under the hood, inside (toward center of veh.) of the brake master cylinder and follow the steel line from it right to the slave cylinder. It doesn't go anywhere else - a nice simple little system.
easy as pie
I replaced the master/slave when i first got my truck. (first in a series of many, many repairs :doh: )
it is VERY easy.
but first try to find out where you problem is. Ad brake fluid, flush out system. (Do you know how to blead breaks?) you might only have to replace one of the units. I redid all the hydrolics on my truck... but never replaced brake MC and 3 years later it still works just fine.
i recommend spraying down all the brake line fittings with Kroyl, or WD40 for a day or so before tackling the job. then you might also want to invest in a pair of vice grip bolt grabbers (i don't know official name. they will hold the bolt on three sides and are wonderful to preven stripping rusty ass bolts.
good luck.
:bounce2:
I just now got off the phone from NAPA to order a clutch master cylinder for my 8/75 FJ40. Brand new beck/arnley $62.00. I have been adding fluid since I bought it 2 years ago and it just started leaking alot faster. I was trying to hold out because I'm putting an automatic, but filling it once a day is a bit much.
