Newbie checking in
Yes, it's a UK Car.
So far all I've "had" to do was full fluid/filter swap, front brake pads & I replaced all underside brake pipes for copper.
Plans for the truck (this year) as follows:-
I've just bought a set of TJM +2" springs (I'm about to order matching shocks) so plans are lift, 285 MT's, front & rear axle strip & rebuild, rear discs & pads & new handbrake shoes.
Not in any particular order though.
i would recomend fitting the CDL switch, very usefull and easy mod. check the rear axle breather too, mine was rusted solid and on removing it i could hear the pressurised air escaping.
Nice!
:flipoff2:
ignore me if im telling you what you allready know :)
when low is engaged so does the CDL. once the CDL switch is fitted the CDL can be engaged in high and disengaged in low. great for towing/hooking up the trailer etc.
