Newbie AC question
Mission BC
It is not yet clear to me how AC works in automobiles. When I decide to turn on my AC is it more cost effective to cool the truck at full fan speed rather than low speed? Does AC pull a constaint power or does the power it uses vary depending on fan speed etc? I can understand if my temperature sensor turns it off, then it saves, but perhaps it's best to cool the truck quickly, then cycle the AC.
Thoughts?
The fastest way to cool the cabin is to have the fan on high right from the start. (Although someone did post otherwise a week or so ago.)
As for cost?? That's got to be pretty negligable, but even there high would technically be better for getting the cabin temp down to a given temperature. Why? Because whenever the compressor is running you want to be making full use of it: It doesn't work "harder" at certain temp's and/or fan speeds; it's either spinning or it's not. So when it is spinning, you want to maximize its efficiency by passing as much cabin air through it as possible. (Basically the same principle as how when an engine starts to overheat at idle, you can often cool it back down by revving the rpms: More coolant flow *and* more air through the rad.)
Of course lower fan speeds will use less energy per unit time (as the compressor will click off more often), but again, for getting the temp down to a set level it's just not as fast and not as efficient.
Curtis
To get lower vent temperatures you will want to slow down the fan speed. It may not cool the cabin temps as fast. The evaporator can get much cooler when you are not pushing a high volume of air across it, and it will cycle more often.
Another thing that you will want to do is to have the recirculation button depressed to pull the temperature down inside as quickly as possible. At some point the air inside will eventually become cooler than the ambient temperature air that you would be sucking from outside the cabin and across the evaporator if you do not have it depressed.
