Newb with Transmission Troubles
Austin, Texas
1993 FZJ80
My transmission is acting up - it won't shift into overdrive, and when the shifter is in Drive, both the D and the P (drive and park) lights are lit up simultaneously on the gauge cluster. If I put the shifter in Park, same result - both indicator lights are lit up. If I'm in Neutral, Reverse, 2 or 1, only the corresponding light is lit up.
Once in a while, it would try to still shift up into overdrive. When it did, it was a fairly rough shift, and only lasted a few seconds before it would drop back down into 3rd, again with a pretty rough shift. The O/D off switch seems to still function fine, so I locked it out for the drive home at only 55mph. ECT still seems to work fine as well, with the exception of shifting into overdrive.
I checked the fluid in the transmission, and it's at the correct level (as best I could tell at 11:00 pm in a gas station parking lot), not burnt smelling, and still bright red.
I'm quite new to these 80's, but pretty handy with a wrench. Where do I start looking - shift solenoids? Do you think I'll be doing further damage by continuing to drive it around town?
Thanks,
Mark
Well, this is just a shot in the dark, but I did just replace my tranny by myself a few months ago in my '96, for whatever that's worth. Maybe that'll give me some cred. :D
Anyway, have you checked the adjustment on your transmission cable? Also, remember that the tranny won't shift into 4th until it's up to operating temp.
Jon
I'll look into adjustment on the transmission cable today - thanks for the tip.
Operating temperature shouldn't have been an issue - I had pulled my pop-up camper 25 miles home, dropped it off, went to Home Depot & picked up a lawn aerator. Back to the house to drop that off, then sprinted 50mi down to Denver to pick up my neighbor's who were stranded down there.
