New Warn 9.5XP installed
Beaumont, Texas
Website
www.marklowimagery.com
I just finished installing my new 9.5XP on my ARB BullBar on my 80. I found some very nice chrome plated steel 1" spacers which placed the winch perfectly inside the bumper without the motor touching. But just what is the best way to mount the control pack? I tried to install it facing forward with the included bracket but it came in contact with my Hella Lights. I finally got it placed facing upwards using the bracket and this also places it sort of behind the bar which I guess will protect it from rocks etc. Is this where others have mounted theirs or is there another solution I overlooked? The leads out of the control pack are somewhat limiting since they are just long enough to reach their connections.
Mark
Slee makes a bracket that hangs off the front winch crossmember. It also gives you a place to put your license plate, but you could cut that off if you wanted. You can kind of see it in this picture:
I'm not sure if it would work for you, but thought I'd throw it up anyway. You can spin the mount forward or back to get the position you want, and you can bend to adjust the angle.
keep the box as little in front of the rad as possible...
Ok thank you.That is what I needed to see. My bumper I think is a little different but the silinoid pack is mounted alike. I'll try to get a quick picture on here of mine if I can figure out how to attatch images. I think this image will work.
Thanks... I like the fact that it does not stick out like a sore thumb. I guess it is sort of hidden behind the lights which helps. I was looking at the synthetic winch lines and also thinking about a Hause fairlead instead of the warn rollers. At winchline.com, I found the lines and also aluminum roller fairleads in black as well as aluminum Hause fairleads. Weight was partially taken into account when deciding on which winch to go with and this 9.5XP with 125' of 5/16 cable weighs about 87lb. I can knock off another 19.1 lb by going to a 5/16 synthetic line at 125'. I'll bet that when I added this winch, I probably dropped the front almost one inch because before I started, I used my roller seat to get the winch in place up under the front bumper, and the back of the chair just missed the bumper barely. After I got the winch on the bumper, The chair would not come out the same way because the bumper had dropped. And yes I can tell a slight difference in the feel of the front suspension and steering with the extra weight. Not bad though... Probably a little better in fact that since I installed the 4" Slee springs, and kept the OME 3 deg caster correction bushings for now until I install the caster plates from Slee which I already have, I notice that the front seems to track slightly better with the weight in front. I could almost drive straight down the road again with one knee on the wheel but still not like pre lift. anyway, these were some of my initial observations after adding the winch.
Cost with two day shipping from WinchDepot.com was 899.00. I installed it myself in the driveway. I placed it on my roller chair and wheeled it up under the bumper, then I attatched two Tie downs around the winch and over the top bar on the ARB, and lifted it into place easily and was able to lock it there while I bolted it up. What I found that worked great was at ACE Hardwars, they have in the fastners section, a chrome plated group of fastners. I found some very think 1" chrome spacers which fit the surface area on the winch feet, and the 3/8 bolts were perfect fit in the center. This gave the winch motor and body enough clearance from the inside of the bumper. I also had to get some 2" long 3/8 16 bolts to replace the ones that came with the winch. That was it. The only other thing I ran into was the opening at the bottom in the bumper where the fairlead mounts and feeds the cable through, the bolt holes on the fairlead was a little to low which allowed the cable to run across the bottom edge of the bumpers opening and then onto the bottom roller. I just punched holes about 1/4 inch above the predrilled holes in the fairlead which notched it enough to allow adjusting fairlead 1/4" higher in order to place the cable in the clear through the bumper and onto the rollers, Yea it would have made it easu=ier to have had help but I am used to working alone, it just takes me longer but I end up doing a better job and with fewer mistakes. I'll see if my pivtures are good enough to show the inside of the mount and the spacers used.
