New suspension install question: What needs be addressed on the OEM suspension electronics?
South Florida
Gents,
Getting the new Ironman 4x4 suspension bits installed tomorrow. What do I need to have done or disconnected from the original airbag suspension so I do not get lights, warnings, flags, chimes, etc. because I don't have a OEM airbag setup?
Thanks and will post pics after the lift!!
Bob
if you did the metaltech kit for the bags in the rear, that is the last step they show of the instructions. you'll pull 2 fuses under the hood and then unplug 2 plugs out of the ride control box that's on the fire wall behind the driver kick panel.
Just got my Metaltech kit installed yesterday. All went well, but have a question for those that have the Ironman 2" lift installed. I have some positive camber in the front that looks more than normal. Is this normal, or did you have to dial it out more. Or did you have to put in a different camber plate or control arm?
I couldn't tell much of a - or + camber after I had done my lift but I went ahead and had a 4 wheel alignment done anyway just to be sure
