New? shock mounts (1 Viewer)
Meridian, ID
Did I under engineer this? Do you think it will hold up with a SOA or should I fabricate something stouter? Advice? jeers? ;p
Cruiserdrew
On the way there
Sacramento, CA
I understand the logic-but it looks light to me. The same bracket in 1/4 minimum or better 3/8 would do it.
Kansastitty
My '40 is up at Poser's right now but IIRC the welded tab on mine is about 1/4" plate. "Thin gets it in, but thick does the trick";)
Mo' thickah = Mo' betta
If you have room, make a mirror twin of the same bracket and use another knuckle stud. In that case, two mounts of the same(current) thickness might work just fine.
Meridian, ID
Thin is in
That's kind of what I was thinking. Maybe just a little thin... I'm thinking also that it should probably go under at least two of the u-bolts. I've got a piece of 2x2x1/4 that I can fab up that will give me more confidence. Thanks for all the input!!! :D
