I have a noise now coming from what I believe is the right front tire area.
It sounds like a brake lathe, so I figured my brake pads were worn.
I just pulled into the neighborhood after a trail run in Sedona and I heard the noise whenever I past a raised curb or building or anything that allowed the sound to bounce off...
I hopped under the truck to look at the rotors because the sound isn't going away when you touch the brakes.
It seemed to before from my listening to it...but since it wasn't responding I figured maybe it was a stick or something touching the rotor.
Its not a 100% noise at each rotation. Its like 75% of a wheel turn and then it stops. Obviously the noise speeds up the faster I go.
The scary part was it didn't just make the screeching/lathe noise. It sounded as if I had like......bailing wire wrapping around there somewhere. The noise you would imagine if you ran over some barbed wire and it was getting smashed in somewhere.
screeeeeeeeeeeeeeeeecch....plink plink carnage death....screech.
That would be a description.
Does a bad wheel bearing make a similar noise?
Any ideas?
I did peek around there and the rotors are clean, no visible marks as if something was carving a line in the rotor face or edge. No marks on the driveshafts....
Any ideas?
