I began developing a wobble in the steering wheel and slight pulsing or surging when braking. Had the front rotors turned and put new OEM pads on (front only). Right rotor was a lot worse, and almost at minimum spec.
Couple of months later, it began doing it again, this time worse. Steering wheel wobbling pretty bad. Put on new OEM rotors and pads. Perfect for a few months, now surging again, and slight wobble in the steering wheel. Front right is squealing, and squealing gets loud and soft with the rotation of the wheel and the pulse in the pedal.
I looked at the rotors and pads, look perfect. Wheel bearings are all at proper torque and looked good when I was changing out rotors.
This is driving me nuts. Any clues?
And I didn't change out the rears, but am close to doing that. Since problem went away everytime I changed pads or rotors, I figured it wasn't anything to do with the rear.
Thanks.
Thanks.
