- Joined
- Feb 24, 2010
- Threads
- 2,226
- Messages
- 2,226
Blair Equipment Co., Inc. (Swartz Creek, MI), producers of precision sheet metal*holemaking tools and spotweld cutters that are used in automotive body repairs, fabrication*and restoration introduces two new Rotabroach Master Kits. Each of the new kits are an all*in one set containing 16 different sizes of Rotabroach Cutters for drilling holes in materials*up to ¼” [...]NEW ROTABROACH® MASTER KITS FOR THE ULTIMATE HOLEMAKING PACKAGE is a post from: RockCrawler 4x4 and Offroad Magazine
Blair Equipment Co., Inc. (Swartz Creek, MI), producers of precision sheet metal*holemaking tools and spotweld cutters that are used in automotive body repairs, fabrication*and restoration introduces two new Rotabroach Master Kits. Each of the new kits are an all*in one set containing 16 different sizes of Rotabroach Cutters for drilling holes in materials*up to ¼” thick. The fractional kit includes cutters from ¼” to ¾” and the metric kit*includes sizes from 6mm to 20mm. Rotabroach annular cutters are ideal for use in metal*fabrication, restoration, maintenance and electrical applications, spotweld removal, plugs*holes for welding, and automotive aftermarket installations. Each kit is packaged in a*sturdy plastic storage case and includes an arbor assembly, extra pilots, center punch,*washers and instructions on use. Rotabroach Cutters can be used in hand-held electric*drills with 3/8″ chucks and in drill presses.
Rotabroach Cutters are made of M2 H.S.S., hardened and precision ground. The*annular or hollow design cuts only at the periphery of the hole, leaving the center as a solid*slug of material. Because there is no center point or “dead zone” as with conventional hole*making tools, the annular cutter configuration has demonstrated the ability to drill holes up*to 3 times faster and last 10 times longer than twist drills or hole saws. The cutters cut*holes that are virtually burr-free and do not deform the surrounding material, even thin*sheet metal. Rotabroach Cutters are made in the USA.
The Rotabroach Master Kits join Blair’s series of available cutter kits, including*fractional and metric sheet metal kits and a large diameter Rotabroach Cutter kit with*sizes from 7/8” to 1-1/2”. Blair also offers spotweld cutters and kits for auto body repair*and restoration. For larger hole requirements Blair’s Holcutters are available in sizes from*11/16” thru 3″ for materials up to 1/8″ thick. Other tools include the pneumatic Enforcer*Spotweld Drill and the Tornado IITM portable paint shaker which are used extensively in*collision shops throughout North America.
For additional information regarding Blair products, visit www.blairequipment.com.
Link
Blair Equipment Co., Inc. (Swartz Creek, MI), producers of precision sheet metal*holemaking tools and spotweld cutters that are used in automotive body repairs, fabrication*and restoration introduces two new Rotabroach Master Kits. Each of the new kits are an all*in one set containing 16 different sizes of Rotabroach Cutters for drilling holes in materials*up to ¼” thick. The fractional kit includes cutters from ¼” to ¾” and the metric kit*includes sizes from 6mm to 20mm. Rotabroach annular cutters are ideal for use in metal*fabrication, restoration, maintenance and electrical applications, spotweld removal, plugs*holes for welding, and automotive aftermarket installations. Each kit is packaged in a*sturdy plastic storage case and includes an arbor assembly, extra pilots, center punch,*washers and instructions on use. Rotabroach Cutters can be used in hand-held electric*drills with 3/8″ chucks and in drill presses.Rotabroach Cutters are made of M2 H.S.S., hardened and precision ground. The*annular or hollow design cuts only at the periphery of the hole, leaving the center as a solid*slug of material. Because there is no center point or “dead zone” as with conventional hole*making tools, the annular cutter configuration has demonstrated the ability to drill holes up*to 3 times faster and last 10 times longer than twist drills or hole saws. The cutters cut*holes that are virtually burr-free and do not deform the surrounding material, even thin*sheet metal. Rotabroach Cutters are made in the USA.
Link
