New Rig...........another vibration problem
Charlotte, NC
just got the 96' with 158K and it has a "vibration" starting to become worse. It is very noticeable when you first push or let off of the accelerator. best I can tell, it is coming from the front of the car and seems to be more on the passenger side but I could be wrong. Every once in a while, it will become much louder that normal. the car is not lifted. any ideas???
Figured I would start and replace the front 2 Ujoints
Congrats on your new Cruiser. Right off it sounds like the U-joints.
Welcome!
Try greasing the U-joints and slip-joints one at a time , then test drive in between each one to help pinpoint which one is causing the vibration. Greasing them in this manner will help isolate WHICH one is the issue if it's not obvious.
Only put in 2-5 pumps per u-joint and per slip-yoke so you don't blow out the seals or over-pressure the yoke. It is always best to check (and grease) U-joints when the driveline is UNLOADED. Blocked, chocked, and in neutral (DON'T set the e-brake) so the drive shafts can be moved slightly by hand.
Blocking and chocking is critical. All 4 wheels!
I actually have a rumble now too and since my front yolks aren't precisely in phase I'm gonna start with that.
Speaking from experience, I had the rumble and the vibration and my rumble went away when swapped wheels with new/used ones. My vibration went away when I tightened my front wheel bearings properly.
Congrats on the new rig :)
