New Radiator??
State of Jefferson
The other day pulling into the garage after a few mile drive I noticed an intermittent hissing sound coming from the front of the truck. I popped the hood and got out and noticed it was dripping coolant from the front driver side at the corner of the radiator. Also if you look down from above, the top of the bottom tank had coolant pooled all the way across it. I know the gauge is mostly useless but this confirms it because it never moved! The truck never overheated, the coolant level is still pretty high, and there wasn't much more than a splash of coolant on the front axle and underside. It was probably running hot because the overflow bottle seemed pretty full. I think it was caught early enough no other damage occurred (fingers crossed). So after searching it doesn't sound uncommon for a truck around 100K to need a new one. Why do some folks recommend the 93-94 copper units over the newer aluminum ones? I know copper is heaver but does it have a greater capacity to transfer heat?
I am planning on replacing the thermostat and switching the fan clutch fluid as well is there anything else I should change? Anything that I'll have good access to and should replace as PM? I am on the fence with the hoses, they look fine but I guess this would be a good time. I am planning on doing the gauge mod too but right now I just want to get back on the road.
Your thoughts
-Noah
The brass ones and aluminum ones cool about the same. Brass are 3 core, aluminum have 2. The best reason to go brass is cost- about 1/2, OEM or aftermarket.
-Spike
I am planning on replacing the thermostat and switching the fan clutch fluid as well ...
Noah,
You will need the blue-hub fan clutch if you plan to add the heavier silicone fluid. Dan had it in stock when I went by there a few weeks ago. If you are removing the fan clutch then this would be a good time for new drive belts (always use Toyota belts.) Have you noticed any noises from the A/C or alternator idler bearings? If yes, then this is a good time (they are pretty cheap.)
-B-
Thanks for the heads up on the hub why does the heavier fluid mod only work on the blue?
Belts should be good I replaced the after market ones in January because they were making all sorts of noise. Idlers seem fine. Radiator replacement looks fairly straight forward (famous last words) maybe a bit messy with all the coolant. I'll post as I go.
Thanks
-Noah
ps Mike I've still got your bushing press tool I'll drop it in the mail this weekend.
