New problem
If the OP doesn't want advice from a mechanic with years of 60 hours a week wrenching, ASEs, and Toyota training at a Toyota dealership I'll gladly not post here any more. I'll work on my forum edukashun instead.
Dont take offense. What ToolBag said is correct, I've done tons of modifications to my truck and although its not the norm, my solution was the exhaust leak. Overheating solutions is like the dreaded P0401. There can be hundreds of different stories, options, trials, workarounds, solutions and what not to get to the final solution of the issue.
I'll have to remember this with the older vehicles, since I've mostly been at dealerships everything is close to new. I've never seem closed loop cause a noticeable difference in operating temp. Maybe a combination of problems?
Very very likely
Sounds like you got it all. I know plenty of folks that have those work "qualifications" that couldn't work on an 80. Sorry.
Hmmmm, I do a lot with OBD and would say that any two O2 sensor mismatch can cause fuel issues, the sensor post cat senses low temps brought about by cool air being drawn into system via hole/crack whatever. Tells ECU to stay closed loop and engine runs like a bag of nails as the map is wrong for a hot engine which should now be OL.
It may work different in Europe, but the O2 sensors we use here detect O2 concentration in the exhaust. They have to be up to temp to work properly, that is why they are heated, but don't sense temp.
CEL's or MIL's as they are referred to here can be tripped by changing ONE sensor, the second already working out of range trying to correct the misinformation being supplied by the other faulty sensor. TBH we tend to replace them as a pair and rarely get a 'come back', more expensive now but cheaper in the long run.
regards
Dave
On the OBD2 rigs here (like Joey's), the #1 (upstream) sensor monitors the raw exhaust, is used to tune the engine. The ECU also monitors the #2 (downstream, post cat) O2 sensor and compares it to #1, it looks for a difference, if they are the same, it sets a P0420 code. The cat(s) change the exhaust, so could not be used to tune the motor, only monitor cat(s) performance. A P0420 doesn't cause it to go into limp mode, or change motor tune/performance, only indicates that the cat(s) are not as expected. Lot of rigs have run without cat(s) and/or downstream O2 sensor, sets code(s) but runs fine.
Agree, if one O2 sensor is lazy/dead, the other may not be far behind, best to replace both.
This is how the FSM explains it:
I have another lighter here for you...this one is soo pink it glows in the dark. :flipoff2:
Excellent, looking forward to it! Is bright enough to cause a glow around the console lid? :hillbilly:
Got that Tools R Us, heating the O2 sensor function is the same here, to detect cat function but, they cannot detect cat function correctly if there is an air leak before or at the cat so throw a code. The sensor in effect calling 'bad cat' when it is invariably a leak or sensor gone bad.
As an asides, if an exhaust has a hole invariably caused by rust, many try to patch a leak but, finding a welder who can weld to rust successfully can be a challenge. IIRC the OP said he had a hole (might have imagined that), he should sort that first before going any further.
regards
Dave
