new pistion rings!!!
wenatchee
Ok so I just put in new pistion rings and conn. rod bearings and I can hardly get the motor to turn. it takes a 1 1/16" and a 1 1/8" boxxed end wrenches to get the thing to turn. what could be causing this? the guy at the machine shop said that the rings might be to big, but when I got the rings I took in the pistion and had the guy at the parts store make sure he was ordering the right one, I kinda know the guy and I know he knows what hes doing so I know he didnt screw up. so what eles could it be? im so close to getting the motor back in. o and its a 9/1970 1f
did you lube the pistons up with lots of assembly lube? as well as the crank shaft? if not you will need to dissaseble it and do that because that is very important, and could damage your engine on start up.
also maybe did you use the maxi gauges? maybe you need over sized bearings?
Sounds like a clearance issue. Did you plastigage the bearing clearances? Also as mentioned above you need to have a good coat of assembly lube on the parts. You may want to disassemble and check the clearances.
To get proper clearance in the rings, they may have to be gapped. Once the cylinder is honed, you have to put the ring in the cylinder and with a feeler gauge, measure the gap between the ends of the ring, many rings are are sold that need to be ground, you use a little wheel that takes a little off inside the gap. That is not usually a problem for you until the motor is warmed up though. It does sound like improped clearance in the bottom end, or insufficiant lubrication.
I put assembly lube on the conn. rod bearings, but not the piston rings i just used an oil can and put some oil on top of the pistons. and I did use plastigauges on some of the bearings. I've never used them before, but the flater the gauge gets the better right?
You didn't put lube on the back of the bearings did you? This will cause the crank to be very hard to turn. The journals and back of bearings should be dry.
If this is the case you want have to remove the pistons.
i just saw this am going to give you a hard. time. if i understand your previous post correctly, you are messed up. when reading the tapes smaller is not better. neither is wider. smaller is wider, bigger is smaller clearance. you should have gotten a strip with the tape to tell you the outcome after you cranked on nuts. make any sense? jim :beer: :frown:
