New owner thanks MUD!!!!
Oklahoma City
I bought a 1996 fzj80 about 2 months ago. This is how she looked.
The carpet was crap when I bought it stained, pretty smelly, so then this happened. I took all seats out and pulled all the crappy carpet out.
I wanted to identify where the water was coming from so I checked sunroof drains, water was collecting on the inside above the drain plugs.... ( Which were not present) obviously this was the PO "fix". I then took a water hose and sprayed lightly just the windshield for about a minute, opened drivers door........ Drip drip drip on my brake pedal, water in floor board, went to passenger side and same result. Looked at base of windshield inside and saw active water. I also have the notorious DS sliding rear window leak, I have an appointment with a local glass shop that will remove and replace my windshield for $125, if. It breaks then $265.
I also ordered Ironman 2" performance springs that I will install Wednesday, I will post before and after pics for those that are curious, I think the 2" with 33" will look pretty balanced.
Looks great!
The PO painted it in a booth, no rattle can. It's OD green in matte finish. He painted the flare seals ( the car was originally white ) it started to peel so I ordered flare gaskets in black, no more white!!!
Once my windshield is resealed and I fix DS sliding window leak I have to decide to Monstaliner the floor in a sand color or new carpet kit.
And yeah it looks sand in the pic but it's definitely OD green my 12 year old son calls it boogers
Pressure wash the carpet before you drop the extra coin. You'd be surprised how much that helps.
Man I would but it was absolute s#*+, it had water stains all over and literally tore apart in both front passenger and drivers foot Wells. I am going to use Kool it to treat my mildew smell from AC and SG auto bomb once I scrub floors with white vinegar.
Have a v similar truck. No leaks from my ""dog" windows at all. Clean the drain real well. My dog loves those windows. Hangs her head out on the hiway. Made screen inserts for them so she can sleep bug free in the truck. Keeps her away from skunks n bears away from my truck n cooler. Great looking truck. 305 only 33 inch? My 80 has a2 1/2 lift n 285s
Where is the drain for them, I pulled up the gasket at the very back of DS and saw a rectangluar slit?????
Also Milestar lists their Patagonia at 33.1" in the 305/70/16 variety.
