New oil pump rotor?
Maryland
About to install my new blue fan clutch (modified with 7000 cst oil) and belts. Figured I might as well attend to other items while in there, so I'll check the WP, replace the a/c idler bearing, alt. idler pulley, front crank seal and OP seal.
Regarding the OP, a new rotor set runs about $25 list. Although I have no oil pressure issues, I'm wondering if it would be worth replacing as PM while the cover is off?
Anything else I should attend to while in there? Thanks for the input, Paul
Wow.
"While you're in there??"
Fan clutch and belsts ain't exactly "in there"; why not just go ahead and do the HG while you're at it? :D
Cheers,
Curtis
Wow.
Cheers,
Curtis
Okay, "in there" meaning the cramped space between radiator and motor...obviously not to the level of what you consider "in there" CJF. A better term that may be to your liking would be: "the cramped space between the radiator and motor". Your input on replacing the OP rotor set would also be appreciated.
If your rig has good oil pressure, I wouldn't replace them. 1, They aren't a heavy wear item. 2, The gears are already "broken in" to fit the pump housing, if changed to new they will have to break in again, putting additional wear on the housing for no good reason.
They are pretty much lifetime parts. If your remove them, be sure to reinstall in the same orientation with plenty of lube.
Thanks Kevin, just a slight leak in the cover. I'll just repalce the seal, lap the cover and reinstall. I want to replace the stock screws with the torx type I saw another thread (think it was landTank?), but having difficulty finding them. Thought Mcmaster would have them, but can't seem to find on their site. I may try to source form a local fastener supplier.
I have no input on that. I was just givin' ya a bump since no one seemed to be responding...
But as long as I'm here: Your front crank seal is leaking? Surely you're not just doing this as PM?
Curtis
Thanks Curtis, as a newbie I expect a few bumps from lifers...I understand it comes with the territory. Actually, my crank seal is not leaking, but thought it would be a good PM. Now, not so much...
Paul
