New OEM Belts
Columbia, MO
What a difference over the Gates belts that were on it. Contemplated replacing with Gates, etc. but I'm glad I ordered OEM from Dan. Extremely quiet and the same price or cheaper IIRC. I highly recommend. I can actually hear the exhaust now when standing up front next to the engine. No more cold weather start-up squealing either.
Took me a little over an hour. Used a regular box-end wrench for the adjusting nut which took a lot of my time. Like many have said, a Gear-Wrech would have been great to use. Did not remove the battery but had the front "skid plate" off for another reason which made things easier. I'm 6'5" and thin so that helped quite a bit I suppose to get up over the top of the engine and shimmy my hand down in there. I think I could probably do it in 40-45 minutes next time (with a Gear-Wrench).
Followed DougM's instructions and had page CH-9 of the Generator section printed out for a visual reference. Not sure why some people find changing the belts on these frustrating (no offense to those that do). It's all relative I suppose--after my PHH and axle rebuild, most things seem easier. ;)
Don't buy a toothed belt. They whine againt the tensioner and will drive you nuts. Get the OEM's. I learned the hard way.
For future reference, the alternator tensioner bolt can be accessed with a socket and a few extensions through the driver's side wheel well. Move/remove the front rubber flap around the steering box and look in towards the alternator and you should be able to see the bolt. It's even easier than the gear wrench method (which also works well)
Thought about going through the wheel-well. Even bought some extensions to go that route but when it came down to it, I could reach the bolt fairly easily from above. Wheel-well was full of snow, etc. as well so I didn't feel like messing with it. Very good idea though.
