New Mudder
Hello all,
I'm a new member to Mud & am figuring this out as I type. I'm another crossover from Yankee Toys. The list there fizzled up & vanished like a fart in the wind.
Holy Stuffing Batman, speaking of farts in the wind, to make a long story shorter than the really long version (cuz it'll still be long,) I had to take my '78 fj40 to work today. I will usually use it around town or to wheel for enjoyment. It's by no means a commuter. I busted a belt on my POS Silverado & I also have a VW van that I would commute in over the 40. Well, that has no clutch pedal all of a sudden. When it rains...
So anyway, back to the farts & wind & stuff. My truck is backfiring like (ok enough w/ the analogies) & I smell anti-freeze. It appears it's coming from the head. Hence, I believe, w/ my limited knowledge=head gasket. How can I be sure? Could the cold have anything to do w/ this failure?
Incidentally, I'm preparing to do a spring over & am gathering parts to do it--now this. How involved is a head gasket? I'm not a complete mechanical knitwit but I've never shimmed anything having to do w/ autos. I have however torgued a few items.
It doesn't really make a whole lot of sense to me to go doing a very expensive spring over when I don't have an engine working properly to move the vehicle. Any help would be very appreciated.
Hope to hear from everyone & I'm excited to finally be a part of the world renowned "Ih8mud list" even tho part of me still likes a little mud here & there
Greg in Beacon Falls CT
pressure test your cooling system, since you probably don't have a tester, take it down to your local shop and ask them to do it. They'll be able to tell you where it's leaking from. If it's leaking from the head on the outside of your engine thats easy enough to fix (headgasket), but if it's indeed leaking around your valves or cylinders than it may be a little more difficult to figure out. You won't always have white smoke out the tailpipe with a headgasket, it just depends on where the leak is coming from. Good luck with the repair and pick yourself up a repair manual or just come on Mud and ask for help if you have any more questions.
Kevin
If your oil looks like a vanilla milkshake you have a problem with a head gasket. X2 on a cooling system pressure test.
