new member
Hello All.
Just bought a used 97 1fzj80G after a long saving and search. Actually it was produced and imported from Japan on late Nov/Dec06. I have not had a chance to take it to mechanic for a throughly check. From own observation though, it is still in good shape both interior/exterior, no mjor fluid leaks with exception of small trail of oil from the back of transmission housing to the main drive shaft.
Since it's Jap imported version and previous owner lost the orig. owner manuals and this is my first LC, I am kind of lost on how to operate some of gadgets the vehicles are providing.
It's has version of vx limited, 24 valves,gasoline and full options, including the frig. and pretty much stocks. Understand the Jap version is somewhat differ from the one they made for other markets. Aside from asking favor from this forum for the copies of owner's manual, can anyone explain how to operate the diff lock?. Mine has knob on the dashboard located on the left side of steering wheel. It has center, ff, ff/rear. I am afraid to use it now, because of might damaging it. Any inputs/instruction of how to use and take full advantage of its features when the conditions is arised much appreciated.
One of buddy told me not to engage the diff lock when you are in H. It only supposed to be used on L only and should be at the slow speed and how can I tell those diff locks are engaged?.
:) :rolleyes: :popcorn: tj80
If it's anything like the US version, the locks can ONLY be engaged when you're in low range (L). Also, they should not be engaged at speeds over 5 mph accoring to info here. When you turn the knob there will be lights on the dash that come on. When they stop flashing the lockers are engaged.
Shift into low range, and the center diff lock will activate (yellow light)
Turn the knob to rear lock, and one red light will flash..drive a little bit and it will go solid, indicating it's locked in.
Turn the knob one more click, and a 2nd red light will flash....again, drive some and it will go on solid.
Lockers are for LOW traction situations - ie offroad-type use. You have a good chance of driveline damage if you try to use them on the pavement.
Unlocking is the reverse, and they sometimes take a bit of time to unlock
Just so you know, lockers are only intended for use on loose traction conditions. Using lockers and turning on hard pavement is no good.
You should be able to order a replacement from Toyota Materials Distribution, use the download site or maybe run across one on ebay. There's some useful info in it.
:beer:
Rookie2
