Welcome!
First, props to the Tigers.
Second, I wish I could say we had a descent baseball team, but the hapless Texas Rangers will always be second fiddle (at best) to the greatest team in the NFL. Yes, the DALLAS COWBOYS have the best GMs (Schramm, Jones) the best coaches (Landry, Johnson, Switzer, Parcells), the best quarterbacks (Meridith, Staubach, White, Aikman), the best running backs (Hayes, Hill, Dorsett, Walker, Smith), the best receivers (Rentzel, Pearson, Irvin, Owens), the best safeties (Renfro, Watters, Harris, Williams) etc, etc, etc.
Oil Leaks:
Tighten the valve cover, then clean all the oil sludge top to bottom and check the distributer o-ring, rear oil pan sealant (must remove the rubber cover). Also give a good look to the oil pressure sending unit.
Oil usage:
As Truckasaurus said, some consumption is normal. Depending on maintenance and miles, you could have a valve stem seal issue. Check for a puff of blue smoke out the tail pipe on cold starts. This is better repaired when you do a head gasket job and include a valve grind for good measure. The valve stem seals come with the gasket set you need to do a head gasket and or vale job.
How about some pics of your new rig?
Good Luck!
DTaylor
Go Cowboys!
