New HJ60 and question
alberta mac
addicted but not cured
Paradise Calgary Alberta Canada
Website
forum.ih8mud.com
My woman now has a new Cruiser, 1986 HJ60 5 speed with air.
I am not familiar with the diesel 6 cylinder naturally asperated so I am wondering what to keep an eye on and what to address, typical things that may go wrong and or preventative maintenance ? ? ?
We had it certed and did a road test out to the mountains and handled very well with stock tires.
What I noticed was when I poped it in nuetral and coasted there was a loud vibration, this vibration was also present when changing gears.
The rear end also hums, the mechanic had said they topped up the diff fluid.
My next task is an oil change and getting them to do a fluid top up on everything.
I also will be changing all the hoses and doing a rad flush and change to start off fresh.
The story was I was doing my usual cruiser porn search and saw the cruiser advertised and mentioned it to her then changed the topic, she then said hey ! what about that cruiser ? We should buy it. At this point she knew about my addiction and is ok with it !
she just sold her mazda and was without a car.
Low and behold she has her first Cruiser and is interested in learning about repairs ! (surprise to me ! ) :doh::bounce:
Any advice on this model Cruiser is most welcome !
Cheers
A.M.
You should also try to tighten the rear and front U-bolts.
Mine became loose at the back end and I got a nasty vibration when cruising above 80km/t and sometimes below. Especially when engine braking ...
Worth a try :)
Sounds like the pinion nut or flange nut on the t case are loose. Remove the driveshaft and wiggle both flanges looking for play. Might get away with afew degrees of tightening and be good to go.
It looks all really stock. I wouldnt touch the u bolts as they will be nice and rusty and probably break. Make sure the hubs arent locked when you are driving around at non wheeling speeds.
Pump some grease into the universal joints, change your diffs t case and tranny fluid and report back. Chances are you will solve your noise or find out whats causing it after.
Oh hey and as far as 2h issues there arent any. Change oil. Adjust valves, clean up all the glow plugs and regound the battery and such. Your either going to love 24volt or hate it. I ran mine last winter and had a blast. The rust aftermath is a different story
