New here, axle question
New zealand
Hi I'm new here from NZ
i haven't got an fj40 yet just waiting for a good deal to come up, a couple of questions.
I have an arb locker in a h233b, 4.65, nissan rear axle centered with disks, out of a terrano/pathfinder the same axles are under nissan patrols/safaris. do you think it would be a good or bad idea if i used this axle to put a four link suspension setup under the 40
i think the h233b is 59" wide and the forty is 57"? at the front is this a big problem?
just thought i might be able to use axle as if i sold it it would be sold at a big loss.
rob
Things that I would think about are the fact that it is a centered rear axle and I'm not sure of how strong it would be compared to a FJ40 axle. If you are looking to center the rear for an engine swap that bay be a reason for such a swap. Also will you be able to find gears that are are close enought to the front? I no nothing about nissans. My suggestion would be to sell it and take the loss or keep it until you have another nissan.
The H233B is a pretty stout axle, I would say it is pretty comparable to the FJ40 axles, 9.3" (roughly) ring gear and availible with 31 or 33 spline shafts in the US (not sure about NZ), and no C-clips!!!!
Being a Nissan guy myself, I have seen them take a lot of abuse on some pretty built trucks and only seen one breakage, a shaft let go on a truck running 39's with dual cases and 5.13's in the diffs.
If you are planning on running a centered rear diff, it would be a great axle to stick under there.
40 series axles are 55" WMS to WMS. Your best option would probably be using a FJ60 axle which is 58" WMS to WMS as far as width is concerened. The only problem is that 4.65 gear ratio that your H233B is running. I think you can only get 4.56 or 4.88 ratios for Toyota axles. As far as I remember from when I was looking into centered rear axles for my Cruiser, the guideline for max variation between front axle and rear axle ratios was a 3% difference. If you ran 4.56's in the front you'd only have a 2% difference so you might be okay. 4.88's would be 5%.
On my friend's Pathfinder he has been running a D44 with 4.56's and an H233B with 4.65's for a few years now and has had no issues. There are 4.88's available for the H233B if he wanted to match the ratios.
