From what ive read on various reviews of the new d2s mini 3.0 they are real nice and should be small enough for a direft bolt on to the h4 side of the depo lights. There was a member on here swapping the minis into depo housings and they are less than a hour worth of work and hardly any actual fabrication. Stick it in the oven, split the case, remove reflector and bolt in the projector using the h4 adapter they come with, back into the oven, clamp and cool.
On another note, as far as I know or have seen on here I have been the only one to run quad projectors, NOT ebay specials. But rather custom fitted depos. And i believe they were the only ones i have seen retrofitted with halos as well...
Heres the set up I was running....
Depo Housings with black plastidipped trim, chrome reflectors
Main beam position:
Acura OEM RDX single beam projectors (same as the popular tsx projector)
TRS tsx clear lens conversion
8k DDM tuning HID with 55w ballast
TRS apollo 2 shrouds with TRS xa amber halos and white xb recessed halo
Low beam position:
Morimoto mini H1 projectors
8k DDM tuning 35w hid
mini gatling gun shrouds with xa amber halos.
I built a custom wiring harness on each side utilizing relays for each side. Lights were wired to all function as low beams with the center projectors set as hi beams since they were bixenon.
And a better look of the halos in a darker not day time setting
