New Harnesses, Rebuilt Harnesses and ECU Modifications
LexusV8 Engines
Supporting Vendor
Website
www.lexusv8.com
LEXUS V8 ENGINES LLC – WE DO REBUILTS & NEW HARNESSES & ECU PROGRAMMING
NEW HARNESS:
-Complete, Built as Standalone for OEM Management, Brand-new, professionally loomed and all started and tested.
-Manual Transmission Ready – Available pre-configured for either 5-speed or 6-speed OEM 3UZ engine managements for manual applications.
-Left- or Right-Hand Drive – Harnesses built to suit both LHD and RHD vehicles.
-Cab-Mounted ECU Location – ECU is designed to be mounted in the glove box (or similar protected cabin area) for easy access and long-term protection.
$1500 - New Wiring Harness
$ 150 - ECU 5 Speed Purchase
$ 250 - ECU 6 speed
$ 150 - Immobilizer Bypass
$ 150 - ECU Flashing
$ 150 - Air Injection Delete
$ 100 - ECU Tuning
FULL PACKAGE SPECIAL:
$1850 – New Wiring Harness with 5 Speed ECU -Bypassed, Flashed & Tuned.
$200 Discount given if you ship us your old Harness and Ecu.
REBUILT HARNESS: 1UZ(VVT-i only) , 2UZ AND 3UZ (Manual or Automatic)
-Remodeled to Standalone OEM management to fit into any vehicle.
- We wire up your harness so that you have 3 wires to connect.
-We also wire in your alternator oil light, rev count and temp gauge, as well as OBD2 where applicable. Where OBD1 is relevant, we wire it into your fuse box so that you can read flash codes.
-We build a fuse box onto your harness, so it becomes a standalone system on OEM Management.
$750 Wiring Harness Rebuild & Immobilizer deleted
$150 – ECU Flashing
$150 – Air Injection Delete
$100 – ECU Tuning Throttle Response
$5-$10 per Replacement connector, installed
$100 - Transmission Wiring
$90 - Transfer Case Wiring
· $100 - Automatic Configuration
Procedure:
For New Harnesses: send us an order via email to sales@lexusv8.com
For Rebuilt Harnesses: Send us your Engine Harness, Sub harness & Ecu & completed client form (lexusv8.com)
Turnaround Times:
For New Harnesses
: Available immediately. If not in stock, there is 1 week waiting time.
For Rebuilt Harnesses: 2-3 weeks Turnaround time.
SHIPPING: Available in the USA and International.
Lexus V8 Engines LLC -
Florida USA www.lexusv8.com sales@lexusv8.com
