"New" Guy
I'm still looking for pics of the suspension.
The Dawg is only used for mud and sand drags. If we have to make back to back runs it can get hot but it usually only has to run hard for 3 to 5 seconds. The radiator has been recored to a 4 row and I run a high CFM electric fan and a high flow CSI electric water pump.
I used to run the headers down and back but in the deep mud pits the mud would cause the engine to loose power. I decided to run the headers up to avoid the back pressure.
That thing is badass. Where do you guys race, anywhere in WA?
Kevin
When Moses Lake used to have their sand drags we would drive up there to race. Also used to race a lot in Starkey, Oregon at their sand drags and Mud drags. We used to organize and run the mud bogs in Starkey for a few years.
We have talked the track owners at Pleasant Valley Cycle Park here in Boise to build us a mud-drag track last year and it has really taken off. There is a full schedule set up for this year there, 10 races-two a month. Come on over and play with us. http://pleasantvalleycyclepark.com/
So, I tried to load up some more images but I have reached some kind of limit. If I delete some attachments I already loaded up on here for you to see would it take them off so you can't see them anymore?
Ok. I've deleted a shot and made the others smaller so I can load a shot of the rear suspension. Sorry it doesn't show a lot. I flipped the ladder bars 180 deg. (top to bottom) to get more clearance. I screwed in a grade 8 bolt where the front Heim would usually go to let the ladder bars slide back when the springs compress. I have thought about going with a 4 link but decided I wouldn't gain much for what I do...not worth the effort and cost to me. I also run wheelie bars for when we sand drag. The wheelie bars would be too much of a drag in the mud. I usually get about a foot or so of air when I launch in the mud, the big wheel stand was because I got too much traction on a dry starting line.
This shot shows the old headers.
Thanks for the warm welcome everyone.
I'm not sure if this will attach or not. It's a clip a friend made and posted it on Planet 4x4 for me. It's from one of our races in Weiser, Idaho.
wheelstand2.wmv
The rear end set up is a poorman's ladderbar set up. I'm running Competition Engineering ladderbars but set the front end of the bars up so they can slide instead of using a heavier spring roller set up. I'll look through my pictures to see if I have any that kind of show it. If not then I'll try to take some pictures before I take it down for it's winter check-up.
HAHA that video is great!
Bad Dawg, that motor must run on alcohol?
Nice vid.:D
Ed
Those headers are common on pulling trucks and mud buggies here in Missouri.
We run C-14 racing fuel (made by VP rated at 114 octane). No nitrous and no alcohol, they aren't allowed in the street tire class class we run. Nitrous is allowed in the paddle tire class we jump up into but I don't like nitrous....I've seen too many expensive engines blow up with nitrous.
