new guy
New member with a stock 1972 fj40. Does have 2" boby and 6" sus lift. I am taking the body off to have it sandblasted. I want to put a sb 305, 700r, and 241 tc?. any ideas? thaxs. I live in sacramento.
Welcome to Mud:flipoff2:, can't wait to see pics. Why go 305? If your gonna go Chev, why not go with a 350?
Good luck
Kevin
Why go from the stock drivetrain? Also, if you're thinking the 305 will have better gas mileage, there are some discussions around that.
If you're thinking more power and better gas mileage, you should think about a GM 6.2 Diesel swap. There is a write-up in the Technical links (http://cruisers.shoumatoffmedia.com/gm62joe.html) and apparently, it shares the same motor mounts as a 350. Also, you'll get over 20 mpgs and based on your year, you're smog exempt anyways. Diesel is the way to go :)
Welcome to Mud. :flipoff2:
But if you are going to go 6" plus a body lift you should look into a SOA and 2 1/2" springs which will net the same amount of lift and ride a heck of a lot better. What size tire are you planning on running.
As for the chevy engine swap are you choosing the 305, 700r, and 241 tc because thats what you have?
engine swap
i was going to use 231 or 241 tc, from what i have seen on spec sheets they are shorter then the 203, 205, 208. with the 700r i know length is a problem.
