New guy with some questions
Norfolk, Va
Hey everyone, I've been using this forum for a couple off weeks now in my research effort and I've hit the point were I think a pointed discussion could get further in my quest for knowledge. I current wheel a 2004 sequoia on 33's and I'm looking to build a weekend warrior FJ80 so I stop trashing my DD. I'm putting together my cost analysis for how much I need to get a decent start. Likely will tow to dedicated off-roading events but want highway capable for hard to get to camping trips. Looking for 93-97, but if a steal comes along on a 91 or 92 I would probably pick it up.
I wheel with some pretty serious guys that are all in jeeps on 1 tons and 40-42 stickys. I am aware that I will not be able to go 1 for 1 with these guys, but unlike them, I have a kid on the way and will compromise ability for overall usability. I am just tired of slowing these guys down or having to find long ways around and meet up later. I hate jeeps, I love toyotas, hence my conclusion on finding an FJ80 to build. I'll be east coast dedicated so basically big dogs, harlen, uwharrie, rousch etc. Goal is 37 radial (or basically 36.XX for most the tires I've found).
Slee seems to be, from what I can tell, the industry standard for kits that are all inclusive. Man-a-fre, seems to have some kits that have similar net lift, but with many less parts (no driveshaft for example), which leads me to believe this is more of a mall crawler type kit. Also, they all use OME springs, which can be sourced separately and a kit can be pieced together and mix in some DIY like I did for my sequoia.
I want to maximize articulation, not compromise in an area that will cause failure due to heavy use but not go overboard because, like I said, kid on the way, and cost is an issue.
Questions
1. 4 inch, 6 inch, 2.5 + 1inch body??? I read a ton on this and still getting conflicting information. I want to clear 37's, 4in(+/-) back spacing, I'm not afraid to trim (sequoia is cut up), but I dont want to do 37s for the sake of having them, I want to actually use the travel and I see a lot of people using a ton of bump stop extension. Then the ramp tests look pathetic. Also read that 6" is overkill and makes these rigs top heavy.
2. Double carden drive shaft? Is it needed even with the angle correcting brackets / new control arms? Because this is a key difference in the Slee kits that would explain the increase in cost.
3. How capable is the factory steering on the 80's? I intend to do hydro assit, high steer, DOM tie rod, etc. Can I wait a season or so without driving around a time bomb? I've seen a handful of 4runners park their rides on the trail with the front tires looking like duck feet.
4. I plan on 5.29 gears right off the bat because its just not a huge cost, but the rest of the axle parts add up quick. I want to run ARBs front and rear. Question is, am I asking for trouble if I run locked, 37's, and gears on stock birfields, and rear tubes? I know its not ideal, but could it be a "wheel it til it breaks" thing and maybe get a year out of them?
5. In regard to lockers, what are other people running? ARBs are what I settled on because of the AWD aspect, lunch box would not go well in the front if I'm thinking about this correctly.
Basically trying to prioritize what I need to get cash in hand to drop on the first iteration of build. I know how these forums can be. I've done a lot of reading, I'm a mechanical engineer, I love yotas, wheel a lot and I tried really hard not to ask stupid questions.
Thanks in advance for the help.
Youve chosen wisely :) No stupid questions but youll get lots of opinions. Mine are as follows.
1) mostly conflicting opinions vs info as everyones tolerance (or description of 'it fits') and terrain is a bit different. Part of the game when you ask 5000+ folks from accross the globe for an opinion of what is best. That said my opinion is stay low as possible. 4" would do. 2.5" and trimming would clear 37s but maybe need a small bumpstop spacer 2.5" keeps things (geometries) simple and cheaper
2) every truck responds a bit different. I have 4" spring and castor plates. Regular oem shaft with new oem ujoints and its happy. The arms alone in the slee kit are a grand and the drive shaft 500 so there is the big price jump between a different brand. I wouldnt call the manafre a mall crawlers lift outside the control arm drop brackets. Seems you would be the type that would be best to avoid those
3) how responsible a wheeler are you? I have ran 37s and stock gears and axles for 5-6 years but follow the 'slow as possible fast as necessary' approach. Have used the skinny but not with reckless abandon. Hammer down types may not fair so well. Only failure ive had was bent tie rod at Golden mtn park. Was a silly simple drop into a creek with million dollar shot.
4)see above^. Granted the 5.29 gives you more torque but My OPINION is youll be fine if you wheel cautiosly and thats not to mean avoid hard stuff. Id pick up a spare long side axle front and rear and keep in truck or at camp just in cAse. Cheap jnsurance untill you can upgrade. Youve likely read the chromo doesnt last as long on road but we still are talking about 40-50k miles. Just consider if you do the 30 spline or 300mm upgrade you wont be able to borrow/share parts with stock friends if you wheel with other 80s
5) ARB is commonplace but still has the potential of leaking air line issues. Lots of pleased customers with the new Harrop lockers. If you are doing part time which looks like a no, some have added an auto locker up front. Will be fine till you spin the hubs and thats likely on dirt.
Id wager
5k purchase price
2k in preventative and catch up maint
2-5k mods. Tires are a huge chunknoff the bat. They arent supported as well as jeep brand somparts cost more. Add skid plate (3-400) sliders (6-900) front bumper (8-900) winch (3-900) rear bumper (500-2500) and youll see it adds up fast.
Also do you care what it looks like and can tou make your own armor. Thats a Game Changer to prices above.
You could always just grab a set of Volvo portals and $800 OME lift :grinpimp:
Thanks you so much. I would say I'm a conservative driver. Mainly because I've had to be wheeling my DD, but I don't think that will change much because I'm married and whether shes with me or not I can hear her voice yelling at my for spending more money haha. I read elsewhere that people run factory gearing on 37s, thats good to know, can put that off my plate with the first buy.
Are you correcting all the other geometries (panard, upper CA's, etc) in your lift and you just didn't mention it or are you actually only running springs and caster brackets?
I have a few friends with tube benders and pretty decent fab capability that like to drink, so a case of beer and a weekend equals a lot of armor for cheap. I'm being patient (not usually like me) and I'm going to wait for a good deal. I think people with factory lockers are starting to discover what they have so they're still running >5K, but I'm finding ugly ones (ripped interior, little dented) for <4K they're just not here. But with time, I'm sure one will pop up within a few 100 miles that I can snag.
I think that if you start with a 5k stock truck you'll blow past 5k in mods in a hurry. arb's front and rear alone are going to put you in the 2's with no labor cost added.
5K in mods for lift plus tires is completely reasonable for a first buy. I know ARB's are super expensive, but it sounds like sounds like gears, lockers, Birf's and shafts will be a 2nd buy. Just trying to get in the game at first, not win the superbowl.
I'm running 37"s 4:10s with a 3.5" suspension, stock drive line, all stock control arms & pan hard bars with no drive line vibs. If you start closer to the 3" range of lift you can most likely stay away from the need of the more spendy items. One could add coil spacers later if you want get to 4" lift. An addition of a 1" body lift gives that 1" extra in the fenders for 37s.
Hope this helps.
Hope this helps.
What springs are you running that net 3.5 inch?
I'm running 37s on a OME J springs, 4.10s. It is my DD. I haven't done any other suspension mods except to remove the rear sway bar. I run Deutsch Tech 8000 shocks with 12.5 travel, rides great in my opinion. Cruise control still holds going through the mountains, and I only have slight rubbing when fully articulated(flares removed). I'd say getting a 91-97 truck, some used J springs, longer shocks of your choice, and removing stock bumpers would be on my list of starting off on making an 80 series a weekend wheeler.
NVM I found this
Thanks everyone, this is all great information more glass half full then I was suspecting.
I'm running the 75mm dual rate Slinky set up that net 3.5" on the less spendy single rate side a OME 850J/863 with L shocks & plates would net approx. 3.5" lift also.
You can either find one that is somewhat built up, or perhaps built close to your goal already that has most of its PM caught up on for probably $8k and up. Or you can buy one for $3-5k, play catch up on PM and then start bolting things on. Either way, I would venture a safe number to start with for your budget would be $10-12K for a reliable vehicle.
I would recommend looking for an FZJ80 over the FJ80. These rigs aren't getting any younger and the number of discontinued parts are growing. Plus you get four wheel disc brakes, full floater rear axle, the 4.5l motor, and the better transmission.
Thanks you so much.
Started with a OME kit:
4 j springs and OME L shocks
2" sway bar drops f/r
Yellow 2* bushings (insufficient)
Over time it evolved some with various pieces.... still don't have all the pieces
It had incredible stinkbug/rake with that setup. Never had driveline vibes because it inadequate castor correction therefore a vague wander at hwy speeds
Added a front bumper and winch which helped castor but hurt stance. Added 4" front springs which leveled it out but brought back the wander. Added plates to fix the wander. Heres where you can see the value of a tried and tru kit as slees vs chasing rhe next issue
Ive since then bought adj panhards and made my own longer lower rear control arms as the same time as beefing them up with 1/8 wall DOM tubing plus 1/2" length for pinion relief.
No bumpstop spacers and no problem with rattle canning the rear frame rail where the tires rub with full stuff. Some folks wouldnt find this acceptable.
That's the setup I am considering since I'm swapping my 315s and 863s from my 100 series to my LX.
Were you running any armor with it?
I consider my rig to be on the lighter side, that's why I have the extra .5" of lift. I'm sure if I had droors, winch & outside spare it would net 3" of lift.
I was running the 851+25mm/862+30mm set up with Ls which netted 2.5" of lift then to my now Slinky dual rates. They AZ Boys that have run the 850J/863 & Ls for many years is @Tools R Us & @richardlillard1 they know that set up better than me. It's a solid & proven lift combination. Give them a PM...
For the front: I plan on running a cheap harbor freight winch because a few of my buddies have them and they've lasted, but its heavy. And basically copying the rock defense front bumper as a DIY.
For the rear: I plan on running a full size space with a swing out tire carrier.
Split decision on internal cage or exo as of yet, but it wont be over built, but functional.
But thats the bulk of the planned weight, is that enough to justify the J's all around? or just J's up front? No to Stinkbug, I actually run my current truck .5 inch nose high.
Do people run 37/12.50R16's on the factory wheels and are happy with it and actually wheel hard? I cheat the recommended wheel width on my current set up by .5 inches and haven't blown a bead but I'm planning on pushing this next ride way further. I've found raceline beadlocks for under $200 a pair and that takes care of the backspacing issue, but OEM 16x8 and spacers would be cheaper.
The OME 851, 850 & 850J have all the same rate of 220lbs & have a final lift from each other of approx 1".
An 850J/863 is a great starting point for a single rate coil suspension. You can add spacers or packers from there.
I run a 7.5" wide FJC rims on my 37"s I picked them up for a whooping $200 bones for all four.
Running a 17" wheels gives more options in tire selection, swamper has the market in the 16" rim market for 37s.
Hope this helps.
Most folks here running 37's have switched over to 17" wheels to open up a wider variety of tire choices. Factory 17x7.5 wheels can be found pretty cheap from 4Runners.
As for stinkbug or level, this is a personal preference. Go with whatever YOU like. I prefer a little stinkbug cause once you load the truck up to go wheelin' and camping your going to loose an inch of height in the rear.
That sounds like a deal on the racelines.
Ive run 37 iroks and coopers stt's without issue on the Sequoia 17x7.5 rims that have an inch more backspacing and no spacers and wheeled moderately hard on the same trails you mentioned. Same for 35s on the OEM 16x8 as well. Harlan, golden mtn, tellico (rip), windrock, crozet, uwharrie. Ill run hard trails from a wagon perspective but not buggy perspective. Have always enjoyed straight sheetmetal and done well mostly keeping it that way.
With an even weight spread like that you may still have the stinkbug. May want to consider a drop to a heavy or 863 in back or up to a 4" in front if you want level.
Check out GW nuggets build thread. Probably more combos shown there than any other one place.
Not a fan of exos but its your rig and you know best how and where youll wheel. Itll add a decent amount of weight others dont have. May research some of the OME comp spring options Check out dugans hybrid cage from ACC. Lookimg for link.
