So I found a small leak in the hose coming out of my EGR Modulator (under the manifold). This was the source of my problem...Let me know how this works out, I have the same problem on my 1995 FZJ80.
Good find. Replace all your vacuum lines while you're at it. It's probably time...So I found a small leak in the hose coming out of my EGR Modulator (under the manifold). This was the source of my problem...
To get to the VSV, you have to remove the intake plenum.
You don't have to remove the plenum to replace the modulator.
Some have rerouted the VSV from under the plenum so they can replace it without removing the plenum.
Good idea, wish I did that the first or second time I replaced it.
you don't HAVE to but you kind of need to be a contortionist to do it...To get to the VSV, you have to remove the intake plenum.
Removing the upper air intake manifold also gives you the opportunity to clean all the passages. Mine were pretty clogged up. Don't forget the vacuum passages in the throttle body or the hard lines.
