New dash bling!
Twin Cities
Website
www.myspace.com
The last time I set out on a road trip I found that the cd changer in the Lexus no longer worked - just gave me error 21 (I think). Now we're heading across WI for the holiday and my wife was talking about how she's excited to listen to some CD's... Since I had the day off I pulled out my old Pioneer DEH-P4000 from a box in the garage and started yanking the dash apart. After removing the factory amp and extending my wires down to that location I got it all put back together. Only three problems remain:
1. Trim kit from the local wally's world doesn't quite fit behind the center trim so I opted to leave it open
2. Antenna does not go up with the stereo on or the buttons on the dash
3. Ash tray light no longer works
In preparation for the trip I picked up a $25 GlobalSat GPS receiver unit and loaded software onto an old Dell Axim X50. $7 dash mount and I've got what you see here:
Hmmm, the LX is a little different than the LC in 97 (mainly thinking of the sub-woofer here.) There several threads about these installs. If you remove the OEM amp, it gets complicated as far as the power antenna, so you'll have to read through them for the low-down on that.
If you haven't hacked and can just plug the OEM amp back in and -- IF -- the LX is the same as the LC on this issue (I'm thinking this is something the LX had [optional height control] for a couple of years before and was applied to the 80 for 1997, IIRC), then all you do is hook the power antenna wire from your dandy new head unit to the feed to the OEM amp. Everything else on my 80 was taken care of by the conversion harness I got at Best Buy.
As you can tell by my keeping the stock 80 amp, my taste in audio gear has lagged with advancing age. The 55 in my avatar came without a radio, so I added a cassette deck which just laid in the front seat until I got tired of it slipping around in the mountains and mounted it in the dash. Never touched 8-tracks. Those things sucked!
Back to the 80, to use the space in the extra DIN spot, I added a three-port 12-volt power outlet tied into the cigar lighted circuit. Then I cut a small piece of 1/8" luaun that slid in to cover the bottom of that spot and make it look OK.
I know how important it is to score the points with the :princess: getting the ride ready for the road trip. This will be our first one since we bought the Cow and we're looking forward to it.:cheers:
GL, and have a safe drive for Turkey Day.
