new cb for 40
tech and Rat s*** Shack do not go in the same sentence :D
freightdog said:
You can get a filter at Radio s*** - just ask the tech.
peesalot said:
thats it , a filter , that seems to easy , really??????
Well, if you want it to be more difficult.....actually the CB is not compatable with your alternator. What you need to do is pull your alternator and the bracket, then while you are at it rebuild your engine (since the alternator is off already, the next steps will be minimal), and then fabricate a new bracket to hold your custom built CB compatable alternator. The belts will need to match the pulley on the new alternator, but your old pulleys won't work, so get new pulleys for the fan, power steering, etc., and then mount them all up. You have to do a dual battery relay and tray, because your new CB will draw way to much power, and you don't want to have a dead battery do you?
Anyway, enough with my BS. Good luck with your new CB. I hope to get one soon as well, so I am not the only one in a group who doesn't know what is going on. ;)
\ the coax cable was routed too closely to the alt and the computer.
Routed it differently and the whine was much less pronounced[/QUOTE]
good advice..also ,find a good cb shop and buy better coax.most stores sell very
cheap coax...the better the cable ,the better the proformance.you can also get cable that is armored.
you can go to a truxstop. most carry quite abit of cb stuff.some have cb shops
close by....
good luck
