New carb for old piggy questions...
NoCo, above FoCo... mofo!
So I got a cable carb from Trollhole and was wondering what others have done on their piggies.
1. Do I need the hose from the crankcase to the carb adapter? Can I just put a breather up high? I have interference with the new carb and the adapter:
2. Do you guys just cut the end off of the cable and run it in to the cable end?
3. Where should I connect the solenoid up to? I can run an extra wire to the ignition, but was wondering if any of these wires might work? I can voltmeter them when I get a battery in...
Black/Yellow, which corresponds to a couple of wiring diagrams I have seen
About that black and yellow wire.... Looks like it may have gotten a little warm...
The good news is I found where it was spliced out and went to the coil. I added a wire to feed the fuel SOV. Just a small repair to the fuel line from the tank, a quick splash of fuel and this piggy should run next weekend!
