New Bolts
NC
Trying to redo a 64 fj45 right now and as many of you know the bolts are no good anymore for the most part. I know it was talked about along tome ago on here but cannot find anything on it, where can i find alot of metric bolts and nuts, i know about fastenal, but is there anyone else out there ? Anyone dealt with any good companies out there.
TIA
what are the most common bolt sizes (diam and length) if one was going to buy them by the boxes?
Hmm... I've been replacing a lot of bolts on my 65.
I would go check out you local little hardware store first.
The local True Value/Ace Hardware/Coast to Coast (store changed names a lot) has always carried a large variety of metric and standard nuts, bolts and washers in grades from 2 to 8.
I bet I have bought $300 worth since I started wrenching on the FJ.
KR;
Like G_Stratton mentioned; Ace Hardware carries a lot of metric stuff. U can order special bolts too! 10mm and 12mm are the most used. Also, where 5mm is used u can drill these out and retread to 6mm with hex head; instead of Phillips head. Buy SS & silicon grease them when installing.
SOR carries some spcl kits that they have made up. They are useful, expensive; which is why I chose Ace Hardware. Don't forget washers and lock washers.
The problem with the non-JIS is replacing some, but not all of the fasteners. Then you have to keep switching sockets/wrenches etc. while working on the same part.
I never knew it was called JIS, but it sure is a PITA when your replacement bolts need a different socket.
