New belts = more volts
Ashland, OR
I just changed the belts on the 80. The old ones have 35k in 3 years. Scanguage was reading 13.8 to 14.1 volts tops with the old belts. The new belts are in and I am reading 14.1 to 14.4. I guess I had a little slippage going on.
:cheers:
The ones you took off were OEM, right?
I need to do the belts on my cruiser.
one could spray tacking agent on older belts to see if it makes any difference...
Yes they were OEM. The wear pattern on them was perfect. They were probably loose from lack of adjustment on my part. Since they are in perfect shape they are now in the trail spares box.
:cheers:
I thought about that. But at this point I wanted to change them while they were decent. I am building a supply of spares for future emergencies.
:cheers:
wonder if it would affect coolant flow too... bigger pulley I guess, though...
(the voltages in the OP, that was at idle?)
The idle voltage was @ 13.8 with the old belts. With the new belts it went right to 14.1 at idle. It took very few additional RPM's to get to 14.4 volts. I did try the AC as well. It blows very cold. Though I just had it recharged so that could be the reason.
:cheers:
:cheers:
don't hate me, but mine gives me 14.3+V at 750 rpm idle... :)
I won't hate you, but I will tell you your idle is too high :D
good eye! I went in and let it warm up so the idle would go down but I got tired of waiting when it got to 750. Normally, it's more like 700 when it's really hot (and without a/c of course). But that's why I specified the rpm instead of just saying "idle". Will ya forgive me?
