New 80 Series Owner in AZ
Tucson Arizona
Hello All!
I recently acquired my first Land Cruiser, having most recently, previously owned a 2nd Gen Xterra and a JKU Wrangler.
The Xterra was a fantastic overland rig, it took me and my family on some epic trips, but there was minimal aftermarket and it started to struggle on the more technical trails, keeping up with jeeps. That lead me to the obvious decision to pick up a JKU, and hit the harder trails.
Harder trails were great, but overlanding suffered, as did general comfort, daily driving a modified Jeep.
With that, I went back to the drawing board, picked up something more comfortable to daily and decided the overland and wheeling rig would be a weekend car at most.
I considered a number of options and ended up with the 80 Series Cruiser having all the best of both world features from my two previous rigs.
With the hunt on, I found a 93 for a good price that seemed decently well sorted.
The Listing:
What ended up coming home with me:
And how it looks now:
After diving in, it does certainly need some love and has a few issues to correct. I plan to fully leverage the forums here and my proximity to Overland Cruiser to get this rig back in top form. After that, its time to retread some former adventures like the White Rim Road in Moab, the Mojave Road, and Anza-Borrego in California. Then on to some new adventures for me like Black Bear Pass and eventually I would love to run the Dalton Highway up to Prudhoe Bay.
One of the things on my fix list... is just about every rubber bit in the suspension.
I believe a complete lift kit should cover me here. Looking at ExitOffroad and DeltaVS, I think I came up with a shopping list that should just about fully refresh everything.
Anything here I'm doubled up on or wiser choices I could make? My initial plan is a 3" Lift, 315/75R16's, and as much flex and I can manage.
I think the Metric 35" and 3" Lift is pretty much a standard package, but would love any comments or feedback.
Dobinsons C59-612V 3" Flexi Front Coil Springs | Land Cruiser 80 series - Pair
Dobinsons IMS45-60912 Front 2.6" IFP Shocks Pair | Toyota Land Cruiser 80 Series (4-5" lift)
Dobinsons C59-613V 3" Flexi Rear Coil Springs | Land Cruiser 80 series - Pair
Dobinsons IMS59-60687 Rear 2.6" IFP Shocks Pair | Toyota Land Cruiser 80 Series (4-5" lift)
Dobinsons Big Bore Land Cruiser Steering Damper for 60 70 80 series 1980-1997
Dobinsons Rear Brake Proportioning Valve Extension (LSPV) for 80 Series 1990-1997
Dobinsons SE59-516 Front Sway Bar Extension Set | Land Cruiser 70 and 80 Series
Dobinsons SE59-517 Rear Sway Bar Extension Kit | Land Cruiser 70 80 Series Side Chassis Mount
Dobinsons Front Adjustable Panhard Rod | Toyota Land Cruiser 80 Series LHD 1990-97
Dobinsons Rear Adjustable Panhard Rod Track Bar | Toyota Land Cruiser 80 Series 1990-97
Dobinsons Land Cruiser 80 Series Upper + Lower Rear Trailing Arms Bundle 1990-1997
1 × Dobinsons Adjustable Rear Lower Trailing Arms Pair | Land Cruiser 80 Series 1990-1997
1 × Dobinsons Adjustable Rear Upper Trailing Arms Pair | Land Cruiser 80 Series 1990-1997
Dobinsons 80 Series Front Bump Stop Extensions Kit (1.0-2.0 in) 1990-1997
Dobinsons 80 Series Rear Bump Stop Extensions Kit (1.0-2.0 in) 1990-1997
Timbren Active Off Road Toyota Land Cruiser 80 Series Front Bump Stops 1990-1997
Timbren Active Off Road Toyota Land Cruiser 80 Series Rear Bump Stops 1990-1997
Land Cruiser 80 Series Extended Brake Line Kit for 1993-1997 w/ABS up to 6" lift
DeltaVS 7075 Steering Links
555 Tie Rod-Drag Link End KIT (all four)
DeltaVS FJ/FZJ80/LX450 Rear Panhard Lift Bracket 3-inch
DeltaVS FJ/FZJ80/LX450 Caster Correcting Front Radius Arms 3-inch LONG
Just a word of caution, if you want 3” lift and you get Dobinsons suspension, get a lift that they advertise as 2-2.5”.
I have full armor, winch etc, and their 2.5” lift kit is actually more than 3”. Some people report even crazier numbers if they’re on the lighter side ie. I’ve seen 2.5” lift kits yielding over 4” of lift for alot of folks here.
I also got all my stuff from Exit Off-road, they’re very helpful. Email Mike over there first before ordering to make sure you’re getting the right stuff.
I appreciate that. Exitoffroad having example photos on the site heavily impacted my decision. This was the general look I'm going for. I will certainly keep in mind before I pull the trigger on ordering. I'm assuming some tax season sales so I have time to properly plan things out.
Hello All!
View attachment 4051320 View attachment 4051321
The Listing:
What ended up coming home with me:View attachment 4051323
Love your truck.
1st mod would be since your in AZ is the blue fan clutch with thicker oil...15K.
I agree with Kabanstva regarding coils. Get 2" and use coil spacers as needed. Staying under 3" will save you $ and perhaps other issue that may arise with 3+" of lift.
1st pic is Dobs 2" with 20mm spacers (2.5ish) lift
2nd pic is just recently installed Terrain Tamer 2" that netted me 3.25" lift
