New 40" Light Bar
How did you run the wiring from the LED?
Lots of threads here about how to run wires out of car and up to roof rack. Either you go out a door (i do this out a rear door since I open them less) or you drill into roof and use a waterproof connector or grommet.
Do you like the Combo beam pattern? Would you prefer it to be more Flood or Spot?
i like the combo, but I also run 2 8" LED bars on the front bullbar so already have a lot of spot light. The combo is good because the spot section alone is like 18"
Still running strong...have not had a single problem with it. I did remove the cover for it since I was curious how much of my wind noise was from that. It is a bit quieter without it, but it is a nice feature to be able to cover it up and us it to block light on hood.
Glad to hear everything is still going strong!
@shawnFZJ Can you share additional photos of your set up?
I've been looking at these for my FR Wind Cheetah Slimline (v1) rack and asked FR if they had a mounting bracket for it.
They said they are in the process of creating one.
We finally received the Slimline I light bar mounts. Product Code RRAC053. Check them out at www.FrontRunnerOutfitters.com
I know LED light is capable withstanding extreme operating conditions and produces over 21000 lumens of brilliant white light output while consuming less energy.
