New 34" LTBs
which OME springs do you have in the front/rear? Getting ideas as what to expect when I get mine. Trying to decide on which for the rear.
I did OME heavy in the front (850) and OME medium in the rear (860). Got the kit from Slee and it was suppose to be 2.5" but I actually got 3" in the front and 3.25" in the rear. So my stock springs were sagging just a little bit. It clears the 34s with ease. Really want 35s but going to need gears for that. Ah... it never ends... lol.
Do you find them hard to keep balanced? I hear that bias tires flat spot bad in the cold, what's your experience so far?
I don't have them balanced at all. They shake a little bit. ;) They will flat spot if the tire pressure is low and it sits over night but after a minute or two of driving the smooth out. In all honesty they aren't that bad for not being balanced. When I had them mounted they didn't even attempt to balance them.
I think I'm going to pick up an extra set of wheels, probably some taco or tundra wheels and put some LTB's on them. I'll run the stock michelins for the road and then swap the tires for playing.
Might better run that by Tools R Us 1st...
What sucks is BFG won't make a 35/10.50... Only one radial in that size, but it's got a VERY bad sidewall.
Which one is that?
I've run the 35x10.5R16 SSR, and had no sidewall issues. Have taken a stem off on a root, after it got past the sidewall. I wonder what the 15" sidewall vs 16" sidewall damage stats are.
That said, balance has not been great, and they've chunked a bit. Still lots of meat left though after a Vancouver to ACT2006 run, Calgary once...if not twice, and repeated runs to 100 Mile House over two years. That, and daily driving.
There really is a lack of 34x10.5x16 or 35x10.5x16 or similar sized in North America though. Guess the tire manufacturers feel there is not a market.
hth's
gb
