Never Get A Flat Tire Again!!!
Status
Not open for further replies.
Smokey Mountains, N.C.
I have a lot of great products but this one is Incredible..
It's the original Tire Sealant that was used on the Lunar
Land Rover on the moon landing.
Mickey Thompson ,earlier in his Off- Road racing career was losing races because of flat tires and got with these folks and they developed the best Tire sealant in the world.
I offer it on my website.
There are many different grades depending which speed you will be traveling and how much protection you want, but one thing is for sure, getting a flat tire when your off roading is the last thing you want to happen.
Protect your tires with the original tire sealant that will last the life of your tire, seal your tire from the inside, maintain the correct air pressure , seal rim leaks and seal all punctures immediately.
All the rest are pure copy cats. This will never glob up and dry out.
Visit me at Bullet Proof Shop.com
The Lunar Rover (did you really call it a Land Rover? :rolleyes:) had woven zinc coated steel wheels sewn directly to the aluminum hubs, with titanium strips added for traction. No tires.
Lol starting with a lie as a selling point is never good
Stand Corrected
No Lie intended. Just got the product. The tech at the company was explaining to me how it was used on the lunar rover and I assumed it was the same one. My Bad... I was just excited to share the product.
They actually used the product in the Training Lunar Rover out in the desert where they were experiencing flat tires. You can view the pic on my website and the company website as well.of the rover they used. Ultraseal.
Once again, my fault for not double checking the information. You know what happens when you assume something. :frown:
Punctures Vs. Cruise Missle's
Yes Ultraseal will seal punctures up to 1/2 inch in diameter, but that rock is like a cruise missile that went through your tire. Nothing's gonna help that ole tire out for sure.
Ever see those high speed chases when they deploy the spike strips? Turns out that there are at least 2 kionds of spike strips that i know of. One kind is just like nails and puncture the tires. The nails never leave the strip.
Does it help then?
The second kind apparently has needles (like really large syringes) that go into the tire, stay in the tire and tear off of the LEO spike strip.
Will it fill that gap(s)?
Inquiring minds want to know. After all, what if I have a lunar test rig and I'm out on the roads on meth and just don't feel like stoppin and conversatin...
Spike and Roll
Funny you mentioned that. I was just talking the other day about those spike strips.:hhmm: The high performance will seal up to a 1/4 inch hole or 6mm. In the video on my website , they run over about 20 to 30 16 penny nails sticking out of a board and it seals the holes immediately.
I have never seen a spike strip and don't know the dimension of it so I really can't say, but the sealant will work to seal all punctures, and if they are really big punctures it will still try to seal the punctures allowing you to keep going for a little while anyway.:steer:
The other needle strips, I never seen but it would seem like they would have a less effect on the tire if it had sealant in it, but I 'm just speculating.
Now the extreme HD sealant will seal up to 1/2 inch holes which would probably go over the spikes like they weren't even there but you would have to be on a tractor doing less then 25mph due to wheel vibration. :D
Status
