Negative Battery Cable Length?
Mesa, Arizona
How long is the stock negative battery cable? The one that runs from the battery to the side of the engine.
I need a slightly longer cable to fit my Orbital Battery, and I want a battery cable lug to make it easier to attach a winch-- so I figured I would make a new one.
I am planning on routing the new cable along the same path as the stock one, but I wasn't going to bother opening up the harness to get the old cable out or put the new cable in. I will probably just cut the old cable where it is exposed.
And one more question-- it appears that the stock cable attaches to engine with 90 degree-bent cable lug-- any idea where I can get one of those?
Thanks
Jared
It goes down under the oil filter not a big deal to get the old one out.
I am not sure if you can see the pink lettering on the big cable that attaches to the block on the right of the oil filter.
I used some large fine braid welding cable
My negative battery cable goes into some sort of wiring harness for a few feet, before going to the side of the engine. I was thinking I did not want to mess with that wiring harness--so I originally planned on leaving that portion of the old cable there.
But if it is easy to get out, maybe I will just take it out and measure it.
Jared
You may be able to get the length you need simply by removing the ground cable from the harness. I got a boost in length with the positive after I removed the ground cable. The two cables coming together the way they do requires more length. They are easy to split.
I replaced the 4 gauge ground with a 2 gauge flexible ground to help support one of my new mods.
