Need your thoughts please
Crush 4
Motor city
Ok, so I am driving home in my 75 FJ40 w Howell FI when about 25 min into the drive the vehicle dies. It will turnover lights, radio work appears to be fuel in carb., won’t start.About 15 min later starts drive it home. Vapor lock?
Will appreciate any ideas as I dig in tomorrow
Thx in advance
Perhaps post a photo of the carb so folks can see what Howell FI setup you have and what engine.
2028370
thumb
thumb
I’m on an iPhone, but it appears your fuel feed travels over the valve cover. Unless you have headers, probably the hottest place under the hood is the high middle of the engine compartment.
How hot was it outside at the time?
Sounds like could be vapor lock. It certainly wouldn’t hurt to heat sleeve (Heat Shield Products) your fuel feed line.
What's going to confuse folks is whether or not it's EFI or carb'd. Perhaps was just wrong choice of words in original post. I think you're on the right track with it being a fuel issue. If it's EFI look for fuel filters before and after the fuel pump -- it's not a bad idea to change them. Either way, be sure there's nothing in the fuel tank, lines, etc before moving on to the engine.
It was a cooler evening low 70’s. Besides vapor lock I was thinking maybe electrical specifically something with ignition as it is electronic I believe
The vehicle has been set up this way for awhile and comes from Nocal so I figured the vapor lock would have been a previous issue and fixed?
I will check fuel filters/fuel lines tomorrow .
That’s a really hot spot... I still feel a heat sleeve, on the feed, might help... certainly wouldn’t hurt.
Did that Jeep link help with @Downey’s question?
Read up on cavitation and see if you can find any mention of it in relation to your FI.
I'd run a fuel filter upstream (in front of) the 15 psi fuel pump, and another just before you reach the throttle body, probably on inner fender apron away from the engine heat- - -easy deal.
A bit of a newbie so the largest “ canister” is the fuel pump?
Scratch that between that canister heading back to fuel take is the electronic fuel pump. So, gas is pumped to that canister and then fro canister to carb. Should I put a filter before and after canister?
Thx for your patience guys
Heat shield on order
You ever consider non-ethanol fuel? Cured my "vapor lock" problem. Suggested by Poser many years ago.
Yes, Downey is suggesting a fuel filter before and after your fuel pump. But, Mount the “after” filter in the “coolest” place you can find... passenger side, away from engine
I am running non ethanol in my ‘76 now, seems to help with harder starting when hot. The ethanol crap our s*** govt has allowed to be sold at the pumps is not even good for modern engines/fuel systems! Corrosive and less power out of it. On older engines and small engines it is quite noticeable. I thought with FI it was almost impossible to get vapor lock because of the system being under pressure with a recirculating return line? Is that not true?
^^ correct, you won't get vapor lock with throttle body injection. The canister in photo is the high pressure fuel filter. Change it. Location of it should be fine. I believe Downey was also suggesting to add another filter between tank and fuel pump (if one isn't present already) and that's a good idea, however don't use a high pressure canister type filter in that location. Something with low restriction like Holley 562-3 is a good choice. If you have throttle body injection (TBI) then you don't have a "carb" you have a throttle body. Since you're new to it and can't say exactly what you have, posting photos of all the components and location so folks can see what you have is the quickest way to get everyone on the same page and get more help. Next time it dies and won't start, pull a spark plug and ground it to the engine; then have someone crank the engine while you watch for spark. That's the fastest way to narrow down between fuel or electrical issue.
OK a couple more photos. Again I appreciate all the feedback so far I’m making a list. Question anyone know where I can get that fuel filter?
