I have a 75 FJ40 with a 350 conversion. My problem is where to start with the wiring of the vehicle. What color wire puts power from the battery or from the starter to the fuse box. I have found the hot wire for the hei distributor and the wire to make the starter turn over with the key. But I am just hot wiring the vehicle to get power into it. Any help would be greatly appreciated.
I can't remember the colors of the wires off hand, but do you have a wiring diagram? That will tell you. Good luck.
You should get a wiring diagram as they hely a lot but It should be the same color wire that goes to the back of the animeter (on my (77). If you need any more wiring help pm me as I just hacked up my wiring harness and replaced a few wires. Oh I can e-mailing you a wiring diagram if you need one.
There is a white with blue stripe wire that the diagram shows runs to the alternator and to the ammeter. When I hook up this wire to the hot the dash lights come on and will not go off unless I disconnect the wire from the hot.
The white wire with blue stripe should run from the alternator and splits off to the fuse box (then to all accessories) and the ammeter. It goes from one side of the ammeter (forget whether it's + or - side will look tonight) and out the other side of the ammeter to the battery. The wire you hooked up should be on the terminal that the alternator puts out power to. You need to find tho other white wire with a blue stripe and hook it up to the battery. It should be the same size as the one from the alternator to the fuse panel. It is set up like this so that you ammeter can read the power that is going to the battery (charging it) and what power is comming from the battery (draining it) to show if the alternator is keeping up with the power needs of the cruiser. Do you have a volt meter that can show Ohms resistance. It might help to see where the wires go and if there is a broken link.
what dash lights come on and are you hooking this wire upto the battery?
You have answered my question. Thanks for the help. The dash lights are coming on because i have the front fenders off right now and there are disconnected wires everywhere. I just needed a starting point. Thanks
