Need wiring help please
Lutz, FL
I am installing a water to air intercooler and need to wire the coolant pump so that it only runs while the enging is running. I know I need to use a relay but am not sure how to wire it so that it is just on when the engine is, I would rather not have a manual switch. Any help would be apprecciated I am an electrical newbie.
thanks:bang:
Ok well you need to tap into 12v IGNITION not just 12v HOT. You have a few areas to tap into to get ignition hot but it seems like the most common spot is the cig lighter. Depending on what the power requirements are for the pump you could just tie right into it.
The power for the console (including the cig lighter, stereo, and I believe at least part of the climate control area) is fused at 15A.
The cig lighter has a fusible link at approx 5A.
If you do go that route, just remember that you're going to be sharing all that power with other stuff, so I wouldn't be running more than about 5A off it.
/me edits
Google found me these. Pretty cool. Not sure how comfortable I'd be using it tho....
http://www.autotoys.com/x/catalog/FUSE_TAP_ATC_SPADE_LARGE_p_2095.html
Those fuse taps do look interesting any opinions on them?
thanks
I think they would work fine, but I would not use them. I wouldn't want wires hanging out like that, too messy.
