Need Weber Help??
Anchorage, AK
A while back my 40 with a weber 32/36 was coughing and sputtering. So I figured out the there was some junk in the bottom of the float bowl. So I opened up the top of the carb, the electric choke spring thing came undone, so I now have no choke. I need to fix this by next week for hunting. Because who wants to sit in a freezing cold truck while it warms up!!! Is there a preload I need to know???
thanks
in advance
Ryan
With engine cold, open throttle and rotate choke housing till butterfly closes, crank engine and observe the operation.. you may need to rotate it a little one way or another to suit your needs.... here is a general pic.. when removing the top. I remove the top clip on the linkage arm #44.. less hassle for me..
