Need Some help removing axles
Dallas
Website
www.octagonmma.com
I'm pulling the axles for rebuilding, and up front the plates securing the u bolts over the axles are bent. I can't get a socket on 3/4 of them. What can I do to bend them out of the way and get to the nuts? heat them and bend them?
not sure if I understand what you are asking, but I think that the answer is, just cut off the u-bolts, you should use new ones when you put everything back together anyway, so hack 'em off, pull the stumps out of the plate, and you're good to go. angle grinder, cutting torch, whatever you have, once everything is apart, just chuck the plate in the vise and beat it flat.
ditto on what gladly said. Just don'tget too excited when the ubolts "pop" and your under your rig. I always do.
yep, make sure it is held up good, and if you are SOA, I suppose that you would want another set of stands under the axle. one of those stand back and make sure that you have thought of everything before you start jobs. no :beer: until after
